The simulator is cool. Wished it would remember the lat/long I put it. Have not found a way to do that yet. Maybe there is a config file with China in there now !
Yea Cable Cam. Good stuff.
LOL-- not qualified for that -- Thanks!You have to sign up with DJI as a developer.
dev.dji.com - yes you do have to sign up as a developer, but doesn't mean you have to be one.LOL-- not qualified for that -- Thanks!
When you go to run mission under heading mode select "user controlled". This will allow you to left stick the heading you desire as it goes on mission.How do I manually yaw the P3 while in a mission?
If I set the altitude for way point #1 at 100' and then way point #2 at 200', does the P3 arrive at #2 at 200' or arrive and then go to 200..
Is there an automatic way to enter into an orbit mission from a way point mission?
I assume now, you could set a way point, fly to it, end the mission, then play an orbit mission.
Finishes.If I plan a mission that happens to take the P3 out of RC range, is the RTH function automatically started or does the mission finish?
Straight cable line from point A to point B. So in your example it will start at 100' and gradually go up. So halfway it will be at 150' and end up at 200'. So the horizontal and vertical change is happening at same time.
Curious: is altitude "curving" supported (I realize you could create the effect of pseudo-curving by adding a bunch of additional waypoints with geometrically progressing altitudes). The horizontal curving is nice. I am wondering if the horizontal curving calculations are performed by the app prior to (up)loading the course, or if the calculations are supported by and performed in the firmware code - given 2 points and the arc...probably a question for DJI or Litchi developers.
Curious, are you guys running 1.3.2 FW for Litchi app or is there some special developer firmware?
