I'd like to make a comment re: formatting Flash drive over and over. NO benefit. Period.
In the beginning days of flash drives we were still using FAT or FAT32. A bug in the FAT table and you'd have a problem. Reformatting was the only way to reliably reset the FAT table and, *RARELY* detect a bad sector to lock out and I'm talking so rare that I'd only heard of it but never experienced it. Also, if you are performing a "quick" format, you are not checking sectors, just laying down an empty FAT table and that's it.
These days, drives are not only more reliable they do their own failing sector detection in real time and reallocate them from a spare sector area and do lock outs on their own. Plus more likely you are using NTFS which doesn't suffer errors like FAT did and is, basically, redundant and faultless (through use of atom transactions and redundancy checking).
ALL you are doing is forcing the drive hardware (that does eventually wear out) to work harder than necessary and expiring it quicker than necessary.
Short version: These are not your granddad's memory cards, formatting isn't helping at best, and hurting a little at worst.
