Using two transmitters at the same time will NOT increase your range as they will NEVER be at the same exact frequency and will cancel each other to some degree.
Use only one or the other.
You misunderstand diversity!That's diversity is all about. Maybe a little reading will help you to understand how it works.
It's nothing much to brag about it just a 12 inch cable hanging there
It has nothing to do with rang. It is for reception in noise areas.
In the video where the EFPV antenna is giving me trouble, I am flying
under 200 meters and a distance of over 800 meters. The area is over 610 loop, and the Astro hotel. ENERGY Stadium , this area has
A lot of noise. It is still in the experimental stage.
I can say all of my mods have made some improvement. In small amounts.
I want to get more speed, and the power to fly in some wind. Has any one dune this?? Thanks for input.
Hi there reflection. Not sheer I understand what you are saying. The Tx are on the same Chanel. May be I will try using different antennas?/ It is all experimental.
