Can't turn off battery HELP!
Battery error after firmware update, battery center 2 bars have been up for more that 12 hours and can't turn it off, anyone knows what it means when the center 2 bars are fully light?
Try to press button for 5 seconds and leave it for an hour.
Do you have a safe way to discharge say by 20%?
Yes I tried, when I place it in the drone it said battery error and I could not turn it off! All the drone lights were constant red and it was making a constant screeching sound.
Is it getting hot? Keep it at a safe place.
I had once similar issue but got solved in an hour or so. Its a glitch created by some bad charger.
It's not hot to the touch, but I'm keeping it in a safe place just in case
Connect charger and then press for 5 seconds and leave it.
Don't double press, just press and hold for 15 seconds
What does pressing for 15 seconds supposed to do ?
Just to make sure that it is definitely more than 5 seconds!
williamTan, are you in the UK?
Hate to tell you, but I had a similar problem. Tried everything! Week later had to send it in to DJI. Took about a month and a half to get it back.
Thanks alarce! At least i found someone who experienced the same situation, did you send it off with the lights still on? Mine has been on for more than 48 hours !!!
DonT
