340cams said:Thank you...I will do that.
DeweyAXD said:340cams said:Thank you...I will do that.
Make sure you have a compatible devide if you go this route. Needs to be Bluetooth 4.0 compatible so llder iphones/droid phones might not work. Also bare in mind you get this unit bundled as part of the ground station so if you are ever going to invest in that you might want to get the whole lot in one
340cams said:More importantly on my agenda is installing the Frsky current sensor -40A.
Initially, I ordered this because the newest Volt sensor is on back order...it arrived and I was happy to receive it. I then realized I needed XT-60 connectors...wish it would have come with them or at least advertised that I would need them when I made the initial purchase.
Next question I have is installing it. Do I need to cut or unsolder the battery wires going into the motherboard to install this in between the batt? please forgive my novice experience...does anyone have a pic of how they installed their current sensor into their Phantom2?
340cams said:I'm not too keen on messing with the power wires....
Is this sensor an easier one to install once it is no longer on back order???
FRSKY LIPO VOLTAGE SENSOR
http://www.alofthobbies.com/frsky-sp-flvs.html
or does it need a similar installation?
EMCSQUAR said:If I remember correctly the P2 shell weighed just under 250gs (You don't have to take a fly-away for us - not this time lol)
That was just the shell, no legs.OI Photography said:EMCSQUAR said:If I remember correctly the P2 shell weighed just under 250gs (You don't have to take a fly-away for us - not this time lol)
As long as you know I would...you know, IF that were even possible
Was that weight with legs (and their screws)?
OI Photography said:PJA, I managed to grab a couple of pics today for you.
This one shows the pinout arrangement for the 6-pin cable you're missing and the port it plugs in to:
From L-R, the leads/pins are as follows:
Yellow: vid signal output
Brown #1: GND (for vid signal output)
Red: power output
Brown #2 GND (for power output)
PJA said:Hello OI...
You and 340cams were talking about this Lipo Voltage Sensor...
I can use this for any other Lipo other than the P2, right? Does it work like any other voltage sensor? Mine hooks up to my balance cable from the lipo battery and even has an alarm you can set... I don't know if this one has an alarm, but I like the digital display and how it shows all the cells at once... LMK if it's worth the investment... Thanks!
OI Photography said:Related question for ElGuano: do we know for a fact that the NAZA-reported voltage is a truly unadulterated "at the battery" reading?
