its has IDX , LOG , THM , XCODE in thereOpen MISC folder/ Open LOG/ select and copy the AB.txt file you see there.
opened misc then log and it says this folder is empty
got you , coolBtw, for future reference, that is where you can see all your firmware activity.
I found IDX 00 , IDX 01 . log 100 and then Xcode is emptyWhat I do know is that after X firmware version you no longer update using the usb with that controller. I believe it is 1.3.2 or 1.4.1?
yes I did , although there was no beeping sound and it started of with a green light that then turned blue and after pushing in the reset button it came on green again . it looks like they have contact . only the little light on the side of the copter flashes red with green in the background . shouldn't this be green to show it has contact ? it did make some pics while pressing the shutter on remote . I would think that indicates that there is contact right ?Did you do the the last video I posted where the remote and aircraft were on the floor? If so, was it successful on both devices?
Yep , did all that, light on controller is green and I can move the gimbal up and down,there is no sd card in it now.with my flight controller I can actually make the camera move slightly from left to right ? and just did the process again. same still.AS I remember once you get the remote set you have 59 seconds to power on aircraft and press side button with something small.
lights on aircraft are red front continues and back is red green yello as if its warming up if that helps. just now beeping stopped and continues yellow flash. small light on the side however is small green inside and red flashes
you won't believe it but switched on tablet .dji go app . only how to connect , I went into me and signed in hoping that would help.Ok then now it's just a matter of adding the tablet and once connected, enable the app and continue forward.
back to main page . it only comes to where we were before . "HOW TO CONNECT"
did that with 2 different cablesDisconnect cable and connect it right back again.
went into video / photo and it says connect your aircraft pfffffff
not sure , this is an apple mini, any idea where i find that ??Did you confirm the usb setting on the tablet?
