It is corrupt and will not play.
If the crashed P4 will not power up then if you have access to another Phantom, put the SD card into that and power it up. That should fix the video file.
I just received my repaired Phantom 4 from DJI. My Phantom fell out of the sky at 291 ft alt and 526 ft distance. I was flying with Litchi. Dji covered under warranty. I did not have DJI Care. They did not repair my unit but sent what appears to be a new Phantom 4. Start your warranty process here. DJI Repair Service Center. They will ask for everything they need. I sent a lot of info and pictures that they didn't ask for. DJI sent a return shipping label and then you will get updated emails can follow the repair process online. You can PM me for any additional into. Good luck.I was flying my phantom 4 today and at 175 feet altitude she just fell out of the sky and crashed. What is the best way to contact DJI to find out what happened.
The drone dose power up and it did fix the video file. Now got the hd footage but it is the same as the iPad cashed video. Thanks for the tip though!
My Phantom 4 didn't lose power because the props cut off some twigs on a bush. It ejected the battery on impact and crushed the landing gear and gimbal. I lost signal at 152 ft alt and 526 ft away. Healthy Drones showed a crazy zig zag path on the way down. DJI didn't say what caused the crash. So what caused it to crash?I just received my repaired Phantom 4 from DJI. My Phantom fell out of the sky at 291 ft alt and 526 ft distance. I was flying with Litchi. Dji covered under warranty. I did not have DJI Care. They did not repair my unit but sent what appears to be a new Phantom 4. Start your warranty process here. DJI Repair Service Center. They will ask for everything they need. I sent a lot of info and pictures that they didn't ask for. DJI sent a return shipping label and then you will get updated emails can follow the repair process online. You can PM me for any additional into. Good luck.
The temperature was 56 degrees. The battery was fully charged at takeoff and after crash it was at 45%. No bullet holes. That would be terrible if the crash was caused by the battery became disconnected . There should be know way for that to happen [emoji37]
Yes. I've sent it in for repair. I'll let you know how that goes.
You haven't posted any data, so it's difficult to say what might have happened to yours. In the case of the OP here though, it was clearly power loss.
Airdata UAV - Flight Data Analysis for Drones
Mine was clearly was not power loss. On impact the props were spinning with enough power to cut off twigs on a bush. Check out the crazy flight path On the way down. Also notice a wind gust of 19mph at the 3:59 time. On impact it flipped over ejecting the battery. Four crashes, 4 ejected batteries. Maybe DJI designed to eject on crash to prevent further damage. This is the only crash that damaged the aircraft other than props. Now that you have the data why did it crash?
Sorry but I am a registered Airdata user. I get all the data I need when I click on the link provided. What data do you not seem to get?
