My point exactly. Why then do you 'have to keep visual LOS' at all costs as the poster I quoted suggested.The instrument readings in the app give you the information to know those things.
Ordinary asphalt roads shouldn't cause a problem.Thanks Meta, good read. I didn't know about the asphalt part. I'm curious why that's problem when there's no rebar in it. I'm not arguing the point, this is just a new datapoint that surprises me. I have launched from asphalt countless times, never had a problem till today.
My eyesight is not all that good these days, which means I am only allowed to fly 1800 feet away, while my quad is perfectly capable of flying 5km away with 100% control, and I can see my Air 2's screen quite perfectly at 2 feet away? Really?
Even if you still have 20/20 eyesight, are you suggesting that by seeing your quad at 2000 feet you will be able to tell whether it has suddenly developed compass or GPS problems? You will instantly be able to tell if it is reacting properly to RTH instructions? You can tell at 2000 feet whether it is flying forwards or backwards?
I also fly a Blade 350 QX 2 with a GoPro 4. I should have stuck with that, eh?
Hi WetdogCompass calibration ........
I believe this incorrect, or at least incomplete: IF YOU SET THE RTH HEIGHT in the app before you fly, it will ascend to that value (not 20 m) when RTH is initiated. That value doesn't appear to be completely sticky. Although it seems to stay valid on power on sequences, something returns it to default values (firmware upgrades? - need to watch this).
The fact that this critical bit of information is buried under several menus and is poorly explained may be contributing to the problems we see here. I always check RTH height as part of my preflight setup. At 20 meters, I'm going to hit a tree nine times out of ten. I don't want to run into trees.
Smart return to home only works once a flightI don't think that's right. I've never seen mention of it in the manuals etc.
Each RTH instance is quite separate and there's no reason it would prevent using again
I have frequently used RTH multiple times in a single flight.
Easy enough to test this for anyone interested..
Androne, what firmware were you flying when you lost the bird?I am glad for the helpful info from the members of this group so, risking the expected spanking from Snerd for daring to show up in his hobby prior to achieving guru status, I'm going to continue to drill down on this.
If a faulty compass calibration is the accepted explanation I would assume that it went to a false RTH point and landed, right? Since the only obstruction was one very narrow tall building a block away, shouldn't the signal have reconnected once it cleared that building? It would be a huge coincidence that the craft randomly changed course to one that remained directly in that building's shadow. Or so it seems to me.
Not correct . The phantom only needs a gps signal to work properly . Check sensor mods before each flight . Based on those numbers it's easy to tell if you need a calibration. 1.5 million ft and not 1 single issue with any of my flights .RTH can only work if the RC and Aircraft can communicate. Hope you find it.
No sir, just saying you are suppose to have a physical sight of your aircraft. Not what you can see on your Air but what what you can see.My eyesight is not all that good these days, which means I am only allowed to fly 1800 feet away, while my quad is perfectly capable of flying 5km away with 100% control, and I can see my Air 2's screen quite perfectly at 2 feet away? Really?
I undestood what you said - hence my reply.No sir, just saying you are suppose to have a physical sight of your aircraft. Not what you can see on your Air but what what you can see.
True, but Smart RTH is based on the red/yellow/green battery line at the top of the Go app. Smart RTH initiates when the software determines you have just enough energy remaining in the battery(+ small reserve) to return to the home point. This is only available once during your flight. If cancelled, Smart RTH will not reactivate. The others are still available though.Smart return to home only works once a flight
???? I never questioned anything about the RTH functions other than needing a gps signal.True, but Smart RTH is based on the red/yellow/green battery line at the top of the Go app. Smart RTH initiates when the software determines you have just enough energy remaining in the battery(+ small reserve) to return to the home point. This is only available once during your flight. If cancelled, Smart RTH will not reactivate. The others are still available though.
There are 3 RTH modes. Smart RTH (battery energy), Failsafe RTH (loss of RC signal for 3 seconds) and RTH (user initiated). You can activate RTH as many times as you like from the RC or the tablet. I've used it 1/2 dozen times in one flight before.
SD
Sorry Phantom, I wasn't questioning your info. I just quoted your post to preface the differences in all the RTH modes. A lot of users (lately) think they are all the same, and some believe RTH is just an emergency feature, which it can be but there's more to it than that.???? I never questioned anything about the RTH functions other than needing a gps signal.
It was probably coming down, it's really hard to tell sometimes but it definitely was moving down.RTH for me has been very reliable especially for the phantom 3. That baby turns home right when you initiate RTH.
I had one issue with the p2v when I flew up 1200ft vertical from my position(stupid I know) and lost connection, my bird said it was going to RTH but wasn't moving probably because it was confused but eventually it came down. it was a scary 7 min tho. I thought it was going to run out of battery at 1200ft and come crashing! never doing that again.
Cool no worries . I appreciate you clearing up the confusion with the different RTH functions .Sorry Phantom, I wasn't questioning your info. I just quoted your post to preface the differences in all the RTH modes. A lot of users (lately) think they are all the same, and some believe RTH is just an emergency feature, which it can be but there's more to it than that.
No offense intended.
SD
They are just made of compressed crushed rock + asphalt.
But be careful that you don't calibrate somewhere with buried steel pipes or power cables or structural steelwork.
RTH is a convenient feature of the Phantom. When returning from a long mission it is a convenience. If you prefer not to use it that's cool but please don't decide for everyone that they shouldn't take advantage of the feature!
I'd be concerned about needing to calibrate frequently. I would try to find the cause.The problem with the suggestions to not recalibrate the compass is, when the app gives a compass error your choices are to recalibrate or not fly because it won't allow the motors to start until a successful recalibration is complete. Unfortunately this happened so often for me I considered it routine. It now seems to me that the app could be better designed by providing a "magnetic interference" warning instead of simply prompting to recalibrate. IMHO
