Not sure if this is related or not, but before the marshmallow Android 6 update, my Samsung Tab A worked perfectly in terms of connecting with the DJI Go app. Since the update,, and this has been a lot of trial-and-error, I had to enable USB developer options first. Then had to set the USB mode from MTP and/or Charging to RNDIS . Again, this took some trial and error but once this was set I've been able to connect to and successfully use the DJI Go app.John. I'm using a samsung tab-e and I've never had a problem connecting. Sorry I can't help but I just wanted to let you know, it does work.
Uh oh. Mine just updated last week and I haven't tried it since. After work today I'll go home and give it a try and get back to you. I did notice DJI go updated last night to version 2.8.4 . Maybe this update will address this issue, worth a try.Not sure if this is related or not, but before the marshmallow Android 6 update, my Samsung Tab A worked perfectly in terms of connecting with the DJI Go app. Since the update,, and this has been a lot of trial-and-error, I had to enable USB developer options first. Then had to set the USB mode from MTP and/or Charging to RNDIS . Again, this took some trial and error but once this was set I've been able to connect to and successfully use the DJI Go app.
Marty
Sent from my SM-T900 using PhantomPilots mobile app
