FPV for the FC40
you should check this out, I think this is what I am going for.
http://hobbywireless.com/24-ghz-systems ... -p-20.html
http://hobbywireless.com/portable-video ... -1008.html
http://hobbywireless.com/mini-fpv-camer ... p-945.html
I Have order the Turnigy Mobius 2-Axis Gimbal and should receive it within a few days. I want to order the mobius cam also, but I will try to use the gimbal with the fc40 cam for now.
I want to use the mini fpv cam so I cand set the mobius on Time Lapse photo shooting.
I think this is the way to go.
Eric
dtviewer said:
I believe with the FC40 you need to look at a 2.4 FPV set up.
Hi DT.
I quite agree, but if the transmitter and a/c keep swopping within the 5.8 channel would the FPV link REALLY interfere if it were on a fixed narrow band frequency- if you see what I mean.
I don't know enough and have not got the knowledge to answer that question, and I am hoping a tech will answer this one.
Pete
The question is do you really want to risk it?
DJI moved the FC40 up to 5.8GHz for a reason when they attached a 2.4GHz camera.
No - you are right - I will not chance it. Looks a nice bit of kit for the price too. Shame it isn't on 2.4
Light bridge is good but for £800 odd its a bit pricey.
I got a 400 mw 2.4 Ghz video transmitter and matching receiver and it works quite well. I did buy a higher gain antenna for the receiver, it was less than 10 bucks at Amazon.
I also got a backup monitor made for use in a car for the monitor. It has a 7" screen and it was well under $30
deltamike said:
Thanks Eric.
Keep me up to date of how you are getting on please.
I finally went with a digital 2.4Ghz 1000mW Tx/Rx
http://www.hobbyking.com/hobbyking/stor ... _NTSC.html
It's a bit heavy but works great I also bought a 7in screen.
I use the camera now but will connect my mobius camera eventually.
I just finalize the set up of the Tarot Mobius gimbal and it works great.
Phantom.JPG]
I have used the Boscam 5.8G 200MW and 500MW video transmitter in a 5.8G FC40 without any problems. I think modern transmitters use much narrower bands and band switching with should prevent any interference problems.
Chers
John
robvalduga
