- Joined
- Mar 13, 2015
- Messages
- 1,064
- Reaction score
- 309
It's kind of a shame all this extra work is going to be a waste in a couple weeks when the p4 comes out with 35 mins flight time stock.
All those sensors take power.
If you plug the lipos into the battery they will start charging it. So push smart battery in ,turn p3 on, then let bird go thru warmup/app checks. Then right before take off plug in lipos. Do reverse when it lands, unplug lipos then shut off smart bat
Any harm in plugging the lipos in as soon as the smart battery is fully turned on, rather than waiting until after the warmup/app checks?If you plug the lipos into the battery they will start charging it. So push smart battery in ,turn p3 on, then let bird go thru warmup/app checks. Then right before take off plug in lipos. Do reverse when it lands, unplug lipos then shut off smart bat
are they normal lipo. as i known, Turnigy nano-tech is not LIHV.Ok, so my HK Nano-Tech's came in today. I bought a couple 4S 1,800's and a couple 4S 2,200's.
I was wondering the same thing . That's the way I have always done it .Any harm in plugging the lipos in as soon as the smart battery is fully turned on, rather than waiting until after the warmup/app checks?
I actually do the samething I boot the drone up with an old battery so it can warm up and acquire satellites then I power down and put them on a battery in and turn on it's ready to rock.You don't have to wait until after the warm-up to plug the lipo's in ,you can plug them in as soon as you turn on the smart battery. I wait because I don't want to waste precious lipo battery life. I do all my warmups and app check routine, then start the lipo juice. I see no reason for the unit to be drawing from all three just to check on things sitting on the ground. It may or may not use up that much but we are all on this post because every little bit counts right
Tony at FPVLR said increasing the boosters power will not help from 2.5 to 3 Amps, because there is not enough power to initially drive the booster to its max output. He said normally the booster only supplies about 650 MWatts of increased power to the antenna. He also stated the same thing goes for the birdside amp. This is from memory, but I think you get the idea.Without a birdside mod, using just the FPVLR v2 mod with both 2.5A Sunhans boosters, I have tried Auto Channel and Custom 22 and 21 and 20 with far worse results than I had with Channel 30 which shows no interference at all, while all the others under 23 are saturated with heavy interference. Amplifying interference won't improve the video. I'm replacing the 2.5A video booster tonight with a 3.0A one, with lots of hope. Also, under Autochannel, the video bitrate selection disappeared, so I could not select 4 anymore, and when I went back to Custom, the previous bitrate of 4 was changed back to 6. Don't try changing from AutoChannel to Custom video channels in the air. I lost all video for several minutes including the RC connection! Also Autochannel can't use the 32 channel hack, if you have it installed. It limits you to the limited approved DJI channels only. Only way to use the 32 channel hack is to use Custom and select from one of the channels above 20.
Great idea! After an air conditioned icy cold IMU calibration, my boot up time is under 30 seconds, with full satellite acquisition shortly thereafter, but every second counts. It's either an extra margin of safety or more flight time. Bladestrike has also said that is the best way to get an accurate barometer reading. Let it warm up and then reboot. Swapping batteries during the reboot is an advanced move!I actually do the samething I boot the drone up with an old battery so it can warm up and acquire satellites then I power down and put them on a battery in and turn on it's ready to rock.
Thanks for that input. I'll be testing that today! I have them strapped together so I can instantly swap the connectors and power supply for comparison testing on the video receiving antenna on the FPVLR v2. As long as it won't hurt, it's worth a try!Tony at FPVLR said increasing the boosters power will not help from 2.5 to 3 Amps, because there is not enough power to initially drive the booster to its max output. He said normally the booster only supplies about 650 MWatts of increased power to the antenna. He also stated the same thing goes for the birdside amp. This is from memory, but I think you get the idea.
Assuming that it works as Tony describes, is there any way to increase the power to drive the booster to its maximum power, or is the power that is being referred to the incoming video signal? I recall Tony suggesting you could further increase the birdside power output by adding power to it. On the bird, that would add weight, but on the transmitter, who cares!
