Anti Drop Pins
California (originally Hereford UK)
Is there way of removing the anti drop pins without breaking them?
Yes ... but it's difficult
That's why they give you extras - and you can buy more.
Do you just get behind it and use a lot of pressure or what ?
Reactions: dirkclod
There good ! Like that better than the plastic ones .How folk's say one fell off beats me I just need to know if anyone has a trick to get them off . Can order some for later but need to remove it now
for something .
Thanks Jeff ;)
Reactions: Jeff48920
Dirk. Some guys have used narrow gauge electric wire zip ties in a pinch. Just make sure you leave them loose enough that the weight of the gimbal is carried by the rubber mounts not the ties.
Reactions: dirkclod
I use those tie's on the other 2 just for safety .Am trying something and just trying to see if they can be took off and replaced back .
There on there good :rolleyes:
I've never been able to slip them back through. I've even tried a little petroleum jelly. I think the problem is that the holes have a very slight taper when connecting but you hit the flat side when trying to reverse the process. I just cut them off when I replaced them.
Reactions: dirkclod
The holes also are made up of 4 tabs that spread and then snap closed. I personally can think of no way these things would ever break on their own unless crashed hard.
Reactions: dirkclod
Yea ..afraid that's what I'm gonna have to-do . Was just hoping :rolleyes:
Thanks Jeff ;)
Yes you can remove them without breaking them. Watch this video
at 0:40. It's kind of a pain though. Hint: a small flathead screwdriver to help pry greatly helps.
Reactions: dirkclod
Are they reusable after this method? It looks like the tabs get stretched out of shape and can't hold the pin. Thanks for posting this.
Reactions: dirkclod
How he get's it to just fall out gets me !!! But thanks for that video as it showed me something else I needed :)
Jeff I don't know and was gonna tell ya but still couldn't get that sucker out :rolleyes: I have 2 more but was gonna just reuse those .
Think I will just cut them off when I remove the camera :)
brianklenhart
