M.Tigelaar said:I ordered this, I make it myself
It costs almost nothing
http://www.ebay.com/itm/New-40pcs-Dupon ... OC:NL:3160
Nice I just ordered 5. This is so handy for the cables I make. Thanks a bunch!
robinb said:I got the module.
Just need to sort out how to do cable.
Not sure on the one above as you will still need to do a 1 to 2 split on each of the pins.
robinb said:HOLD YOUR HORSES EVERYONE !
With the naza 2 LED module you do NOT need split out cables, etc etc.
I received my LED module this morning and plugged it in to the naza module after unplugging the LED lead in there.
It works
BUT even better than that is the original cable just goes to the USB port.
but there is MORE !
The LED module has a USB interface on.
Guess what ?
You can plug your computer directly into the that now.
I cut a small slot in the upper lid and let the cable out that way and fixed it onto the top case.
[youtube]https://www.youtube.com/watch?v=ZUhvf7MXSTw[/youtube]
quality control said:robinb said:HOLD YOUR HORSES EVERYONE !
It works
but there is MORE !
Guess what ?
So let me get this straight. The LED pin header on the Naza V2 goes to the USB port on the shell of the Phantom. So when you plug the Naza V2 LED into the LED pin header, you disable the USB port on the shell but now use the USB port on the Naza V2 LED.
I was under the impression that the LED pin header on the Naza V2 powered the ESC LEDs. I guess this is a quick fix. I might still try to retain the USB port on the shell to enable you to use either port. Or plug the USB port on the shell.
M.Tigelaar said:What is the extra weight?
