- Joined
- Dec 7, 2013
- Messages
- 1,206
- Reaction score
- 136
Re: STICKY: Resetting HOME Location & RTH in Naza or Vision
You can downgrade your firmware to the prior version and restest to confirm. Tho if you've already done that prior I'm sure it will work that way again.
grinsven said:BenDronePilot said:I am not so sure resetting the home point ever recoded the altitude, o my the position. Don't forget that there is an option 3 to your scenario where you set home to a much higher location. If your Phantom is already at a height over 20m or 66 feet your Phantom will stay at that height and fly safely to the newely set home location provided it is already flying high enough,
I am 100% sure it worked that way. In the area where I usually fly, the largest trees are about 40 meters high. I used to first climb to 30 meters, then set a new home point. That way, going home would always first climb to a safe 50 m. Since V2.00 this trick no longer worked.
