MaxxUAV.com ItElite MaxxRange Availability
So this has been the best backpack to fit everything I have found, it's the Procraft
That's awesome! How many batteries fit?
That's great and now I can't wait for my MaxxRange panels to show but just looking at mine with the ItElite and the amount of time it takes to assemble, ~5min... I think I'm going to try and source a separate RC case, as it sits now it doesn't fit in any of my currently owned cases even disassembled.
Get to cutting... I did
Reactions: MasterBlaster
Hi jake
I made the modification to my RC and attached the huge panel that you shipped it to me yesterday.
Was so excited to see the difference that it makes range wise .
Unfortunately I found no difference than the stock antenna with windsurfer. So I discontented the big panel and I used a couple of cheap 8 antenna. On the Modified RC and I found them work fine about 20% more than the stock antenna. I was able during the modification to get the stock antenna intact.
1. My question is can the unit that I got is defective ?
2. Do you recommend me amplifying it with devo ?
I understand that every one has a different experience when it comes to different antenna .
I am still happy with the modification since it lets me experiment with more antenna behind standard sma connector
However the big panel did not do any good to me.
Hi jake
Jake can answer, but this has been said several times... There's something wrong. I went 23,000 feet today unboosted!
Better start checking connections.
Fits in a camera size backpack. With 5 batteries .
No bazooka carrying case for this guy :)
Hi jake
Same here. Got a little further than my windsurfer today. Didnt want to post my results because I wasnt pleased that others are getting much further with a $5 piece of plastic and I dished out a lot more.
The windsurfers are great for non obstructed flight... But the maxx or DBS antenna will allow you a wider path through trees, etc.
My guess is something is wrong with the install or the antenna
I think you're wrong.
Nothing wrong with my install. As soon as a tree come into play, signal drops off until I clear myself or raise the bird. Same as the windsurfer. Need unobstructive path . Just not pleased with the results.
Hi jake
Are you using a manual channel or auto?
Hey Fallguy, same question for you, are you using auto or manual channel?
Change it to Auto and try again. Another customer was using channel 31/30 and his results were pretty bad. He changed it to Auto and was able to go 6 miles. I think the larger panel is picky about what channel it's using. Couldn't tell you why though, I need to look into it.
Reactions: Fallguy
Ok Jake , thanks for the quick reply. I will give this a try . Might be a few days.
My first flight yesterday only got me 8800 ft before it dropped. Headed in a different direction and got 15000 . Was able to get 13000 with the windsurfer without signal drop before .
Hope that fixes your issue. What manual channel were you using?
Hi,
I am living in France, do you think that MaxxRange will be increase range ? I am in CE mode and not in FCC mode.
Thank you
Hi,
Thank you
Yes it will help increase range. Can you not just switch it to FCC mode though?
DonT
