ok so i used the app with the wand and i got a bit further before control signal lost, 3600 feet.
Yep, no mods on the bird.Do you get this range with standard bird? without extra antenas in the phantom?
Were your connections made with "perfectly clean" parts, and "torqued" as they should have been?
I know we're not talking about "rocket science" here, but it's pretty **** close. Things have to be just right for them to work to the limits.
We are in the same boat! I've done the same parts exchanges you have and have been flying with the same fpv settings. Weather here has been HORRIBLE and I haven't been able to fly for two weeks. I'm looking forward to testing the lower FPV settings mentioned by Clayton. Let us know if that changes your distance and I'll do the same as soon as I can get out to fly!
I had a chance to fly today at my work which is on the top of a hill with a clear like of sight for over a mile. I used the lowest FPV setting and got out to 4000' before the WiFi dropped off. Not too bad, but I still don't understand how people are getting twice that.
By looking at your pic, looks like you are getting about the same range I get in that type of area. You flying over homes and other things that have wi-fi. Might also have some strong cell phone towers around? Looks like typical distance in that type of environment. To go farther u need to go somewhere where u don't get cell phone signal and no other wi-fi signals, clean air, no wind, 0 Kp index, the solar X-Rays and Geomagnetic field should be quiet, no clouds, ect. Must be a perfect day to get perfect range.
The way to test this antenna is in the same area you where flying before antenna and then after install you are getting twice the distance you got before in that same area then this antenna is working good.
Hi,
I just joined, this may have been already discussed some where.
I have a phantom 2 vision + v3 and I have just installed the itellite DBS phantom mod antenna. I purchased it to help with the control more than he fpv. Just flew a ground station flight about 1500' out.
Fpv no failure, but control signal was lost at varying distances all the way out. Any feedback would be appreciated. Additionally, I would like to ask, are you using ground station to fly out the 3000-8000 feet distances, when testing these long distance flights or are you controlling the phantom??
Yes it does come back, I purchased the antenna because I didn't like the fact that I was losing control signal at what I consider short flight distances. I was hoping to increase the control range. My question was, when this antenna is being tested, is the UAV being flown or is it in ground station flight. On the ground station flight, control signal failed at 500+- feet, came back went out again at 700+- feet, came back, went out at about 900 feet and stayed out for most of return flight. Control regained about 300-400 feet from home point.it does not matter if you lose control signal on a GS flight as all coordinates are uploaded to the phantom and it will complete the mission as per the planned route and it will come back to home once complete.
Yep looks to me a lot of Wi-Fi interference around there. I think you doing good to get that distance you get...., yes there is a mobile tower not far from me, here is a video of my neighbourhood, alot of houses etc
Fpv was solid as a rock, entire flight. Just doesn't give me the warm and fuzzies when control of the bird is lost.
Looking for a solution to this issue. As a pilot of manned aircraft, loss of control is discomforting, to say the least. Counting on autopilot, is a luxury, not a control/safety mechanism for me. I would like to have control further than fpv.
Yes it does come back, I purchased the antenna because I didn't like the fact that I was losing control signal at what I consider short flight distances. I was hoping to increase the control range...
I started at 3000' and have worked my way up to 7300' at the same flying site just by how I aim the antenna. Now it has become a game to go further.Hey guys, just had some time to give this antenna a try,its on a phantom 2 vision + v3 and it looks like it get about 3500ft, is this about right? Just seeing if this is the norm for the setup.
Thanks G
