Is the phantom 3 advanced, or phantom 3 professional the drone for me? I am looking to be able to travel up to 1mile away, have clear video feed, and to attach a drop & release mechanism that can carry a payload of 1.5-2lbs. If not, what do I need to do this. [email protected]
In reality P3 is not designed to carry a load, landing gear is too weak and there is not place below the P3 to accommodate large volume below the shell. Also there is no dropping mechanism.
You might be able to lift it with an Inspire 1. I also came across this 3D printed device that can be used to drop things by simply raising the landing gear:
I'd get a Standard to do coke runs. That way if it gets shot down, you aren't out as much. Definitely don't go with an Inspire. The Standard is slightly lighter and flies for about 25 minutes. I have not tested both to see which one flies longer but I'm pretty sure the Standard does. Although, I would be a little leery of going a mile with it. Good luck.
That didn't seem to go too well. That bucket was swinging all over the place.
The Phantom is not designed to add weight. So any type of load carrying is gonna put you on the edge of disaster. Could burn up the motors. I don't know how the battery reacts but obviously it would eat into the flight time. My advice is, use the Phantom for filming unless you have FU money and just want to **** around.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
