OK guys i need help this is getting frustrating.
Ok so the other day i took off and after 2 seconds my phantom decided to go right and there was nothing i could do to stop it. There was a person flying a small rc device near by so i thought i crashed because of that.As a result of the incident i had to use locktite to fix my gimbal and level out the x axis. I also recalibrated using assistant and made sure all the values are within normal range. Went back at it again, same thing again takes off levels off at im guessing 2 meters for 2 seconds and then does the same thing heads right. I tried swithching to ATTI mode to regain control thinking maybe gps is being weird. I had 9 sattelites and it locked home. Nothing worked i lose complete control and it heads right. As a result of my 2nd crash, the black ribbon on the camera ripped off. I went and bought a new gimbal. recalibrated, made sure there satellites and its flashing greeen and no reds at all. Same thing happens again flys and levels for like 2 seconds and then heads right. Luckily todays crash only destroyed 3 propellers. My new gimbal is safe. I will remove it now untill i know my bird can fly normally. I really dont know what to do at this point. I even re calibrated my controller. I am not sure whats happeneing. This did not start happeneing as a result of a crash.
