Anyone have experience with www.mydronelight.com?
Here's a great revue/description.
Lume Cube - Staff pick on Kickstarter, named USA Today’s Best of CES and VideoMaker Editor's CES Choice Award winner. With this intuitive companion iPhone app, you can simultaneously sync and individually control up to 5 Lume Cubes to create dynamic, dramatic, professional quality images and video to add to your portfolio or upload directly to social media. Photography is the study of light, the right light is critical to the creation of any masterpiece. Lume Cube is controlled by this iPhone app, opening new creative possibilities for photographers of any skill level. The ability to simultaneously sync and individually control up to 5 Cubes through the app makes Lume Cube the ultimate tool for capturing content on the fly or setting up an entire scene. With each light producing over 1,500 lumens in both flash and video mode, these rugged little Cubes are the perfect solution for the novice iPhonographer looking to take their images to the next level or for the seasoned vet needing to add the perfect light to get their desired result. Features/Modes Flash Mode - Fire simultaneously with shutter clicks. Adjustable light output Video Mode - Constant video light with adjustable light intensity (0 - 1,500 lumens) Strobe Mode - Adjustable strobe frequency (0.5Hz - 10Hz) Opto Trigger - Allows Lume Cube to identify external flash sources and fire simultaneously in conjunction with the external flash Red Eye - Fires a pre-flash to eliminate unwanted red eye in your pictures 5 Cubes - Connect and individually control up to 5 Lume Cubes Sharing - Share imagery across multiple platforms directly through the Lume Cube app Library - Save images to your device's native image library Filters - Choose one of Lume Cube's filters to put the finishing touches on your images Dual Camera Use - Functions with both your device's front and back facing cameras Indicators - View Battery and Signal Strength indicators Battery Life - Over 25 minutes on full power (1,500 lumens) video mode and over 4 hours with varied use Flash Specs: 9 flash brightness settings: 1/128, 1/64, 1/32, 1/16, 1/8, 1/4, 1/2, 3/4 and 1 x 1500 lumens 1 flash duration for built in camera mode : 1 second 14 flash durations for pro mode: 1/8000, 1/5000, 1/2500, 1/1000, 1/500, 1/250, 1/125, 1/60, 1/30, 1/15, 1/8, 1/4, 1/2, 1 second Video Specs: 100 video brightness settings: 1%-100% (0 - 1,500 lumens) 8 video durations/strobe frequencies for built in camera mode : always on, 0.5Hz, 1Hz, 1.5Hz, 2Hz, 3Hz, 5Hz, 10Hz 8 video durations for pro mode: 1, 2 5, 10, 15, 20, 30 minutes and always on. 7 strobe frequencies for pro mode: 0.5Hz, 1Hz, 1.5Hz, 2Hz, 3Hz, 5Hz, 10Hz Register your Lume Cube at www.LumeCube.com so it’s unique to you!
Photo Credit: Eddie DiCroce Photo Credit: Matthew Cummins
RedHotPoker
Yeah, so doesn't seem like there would be any way to get the lights to stay on by flashing the red LEDs :( oh well.
SO, my next question would be - does controlling it via bluetooth play well with droning? Specifically, when you get out of range and come back, does it reconnect automatically or is there a cumbersome process that wastes battery? Also, what's a typical range that it works well in?
Again, I'd be elated to be able to control the lights from anywhere that the RC gets a signal, but this would be better than nothing!!
Trying to figure out which headlight setup is best for me...anybody have experience with www.mydronelight.com? I was looking at this one in particular.
dji drone LED Light
I am confused about lux vs. lumens since angle and distance are involved, but seems this might be a good mix of brightness, weight, and cost ($70). I asked if these are able to be angled down and he said they are. Thoughts?
Hello I'm the owner of mydronelight.com
I can help you if you have any questions regarding to the dji lights
dji drone LED Light
DO NOT BUY ANYTHING FROM THIS COMPANY !!! THEY ARE CROOKS!! and will not Honor their Warranty.....
What is the case made out of? I would hope out of metal to remove heat, something like magnesium.
dlr11164
