Thank you for the feedback. The big blue circle as you describe it is your iOS location, we are going to go ahead and remove it so that it does not add to anyones confusion.
Quick couple of questions. What version of iOS are you using? What drone are you connecting to? (P3A, P3P, or Inspire) If you launch DJI GO and then go back into airnest does it change the video stream?
Thanks!
Justin
I loaded the app and noticed the NFZs are larger than in my DJI app. Does your app restrict flying inside the red circles or is that just for guidance?
Just took at look at the app and first thing being from Australia, everything is imperial! Unless i'm missing something you'll need to add this in so we can do altitude in meters and speed in kilometers an hour.
When will the full iOS version be avaliable?
Thanks Justin. I've already signed up on your website. For me the way point feature is the most interesting feature for me at least. Good luck!nickyb, we expect it in the next couple of weeks but that will depend on the feedback we get during Beta. We don't want to release pre-maturely. We will certainly post here when it is released and send an email to our newsletter as well. Feel free to sign up for the newsletter at www.airnest.com if you want alerted.
.... We don't want to release pre-maturely. ..
They want to get the bugs ironed out in the iOS and then they will start working on the Android platform. By doing this they make the transition much easier and only have to work on platform specific bugs there after.Will it work with android tablets, Like my nvidia shield?
ThanksI believe it is IOS only for now. Look a couples pages back.
Looks like in the video, it comes home on a shortest path, not the path it took to get there, correct? Have to make sure you are high enough to cover those trees!
Justin I have some questions for you:
1) What are the distance/height limits of the ap? Since it's not using the DJI Go ap what are the limitations?
2) Will we have any control of pitch during the flight?
3) If the flightpath takes the aircraft out of range or if there is a loss of signal what is the "fail safe"?
1) Height limit is about 400 feet, we are considering changing this for our international friends. Feedback is welcome. There is no distance limit, proceed with caution. In my experience if you fly a waypoint mission outside of radio range the drone continues with the mission independently, the gimbal however will stop updating once a loss of connection occurs.
Excellent. There are times when having manual control over the gimbal would be nice (say following a bike rider )2) If you look 8 or 9 seconds into the video I just posted you will see a manual pitch control switch at the bottom of the altitude selection screen. If you throw that switch then our app will not control the pitch of the gimbal and you have full manual control.
I "assumed" these were stored in the aircraft but wanted to confirm.3) Fail safe's are saved on the drone so you can set them within the DJI GO app. We will add these features in but since you can use DJI Go we did not make them a priority.
