Wifi Module
Someone mentioned to me that the Wifi module on the Phantom 3 is the same as the one on the Vision 2+ Version 3; EXCEPT, DJI drilled a bunch of holes in the cover (and called it an upgrade). If this is true, why deal with the heat paste - just drill a bunch of small holes in the cover.
Someone tried that some months ago and found it created a lot of interference. Your mileage may vary though.
When replacement is necessary, the very least we should do is replace it with the one for the Phantom 3 - will it work?
No. They are not compatible. You should use this one.
Exactly :)
Wifi module in a Phantom 3? o_O
Yeah, I was thinking there should be no way I'd get to the end of this thread before someone questioned that.
To the OP, the P3 does not use wifi at all. Period. It's radio operated on the same 2.4ghz band but does not use wifi.
Reactions: bbfpv
