Why the extra gimbal mounts?
Why does the P3 come with four extra rubber gimbal mounts? Do they go bad quickly>\?
And why are there only to retaining pins on the gimbal mount? Seems odd but there must be a reason.
And to answer my own question, a minute more research would show that you only need two retainers. Still not sure why they package extras...
The extras are in case you need such as after a crash.
There are only two anti-drop pins installed (diagonally) on the gimbal mount. That's all that is needed.
OK, if that's the case, DJI should have packaged the kit with a half dozen propellers instead of the extra two.....
because if you have to remove the gimbal/ camera-- you will need the extra pins-- because you will probably damage the originals trying to get them out.
Michello
