Vision camera lens
Manchester UK
Using the lens adaptor kit, can you get one to straighten out the fish eye effect, or can this only be done in Adobe ?
I wonder if that would work on the plus models also(the fish eye effect bugs the crap out of me)
When I can get a replacement gimbal I may send in my p2v(non plus) camera
Or you can make the adjustment in the app to narrow and the fish eye almost goes away. When I first got my P2V and saw my flagpole bend over like a pretzel, I thought the camera was broken. Narrow fixed that problem.
I will try it next time I fly
Try seeing your house look that way from above :?
My non plus vision isn't was bad on the fish eye effect as my vision plus(could just be me :p)
Yes, it's you. The cameras are identical - just the Vision is in a bigger housing so it looks different.
Not seen that option mate, is that just for pictures or for video as well, and where in the app is it ?
In the app over on the right side under where you select camera or video is what looks like a gear. Press that. It opens up settings on the left. Third item down in the settings list is the different video quality you can shoot in. Touch that, window that opens has the different size settings on the right. Find the screen that looks the smallest and press check mark. Tap gear icon to close settings.
I guess I am noticing it more because it has more range of movement then my p2v(none plus)on the gimbal
I figured they are the same camera hardware
Does this affect the pics and video??
Well, yes. It adjusts everything the camera does. Quality, frame rate, size.
Thanks for clearing it up
AnndyManuka
