Update stuck at 99%
Baton Rouge, La
I am doing the latest update for my P4P through Go4. It cycled through as most other updates, but it has been stuck at 99% for 30 minutes.
What to do?
Restart your P4P and check the "General Settings" --> "About" section of DJI GO to verify the firmware installed.
Mine had the same, stopped at 99% so I powered off, restarted, then it updated the controller and all was well!
Which version do you see if you connect your Phantom to your computer and start the DJI Assistant 2 application?
I restarted AC, controller, and Go again. Now I have AC version 01.04.0602 .
But still no video feed in Go or Litchi. The HD bars are flashing from full to none in Go and 100% to 0% in Litchi
Good!
Did you update the remote controller firmware?
If DJI GO is not prompting you to install the update, then connect your remote controller to your computer via a micro USB cable and update it with the DJI Assistant 2 application.
The DJI Assistant 2 application will not prompt you to update. It'll show you the current version of the firmware that's installed on the remote controller and allow you to upgrade it if a newer version is available.
Where it says normal on the DJI app. Hit the arrow to the right and it will prompt you to update
Got a screenshot?
The status light on my RC is also flashing very quickly red/green when the AC is on
I found that the easiest way to update firmware is on the dji 4 app. Click the status bar which is saying no image, no connection etc. the first line should say normal. There click the arrow and should prompt you to update rc.
ctlfreak
