Sorta but you don't cut the camera on Lonewolf . Erod you have read the quickstart..right ?Right and sorry I forgot the Standard uses wifi from the camera to send signal back like the Phantom fc40 did. With that setup, you had to turn on the camera to enable the signal.
Upload what ?I will try that soon. I wonder if I can upload video to show you guys
In the screen you put up did you swipe it to the one I put up ?Post a video about my issue
Erod do not power up your bird with out reading the quick start .
You power up your bird with the camera locked and ya might mess it up .
I don't know just what you've done . Start up update takes a little while and that screen you put up is wrong for the standard .I did read the quick start and everything. I was doing the firmware update and it stopped and the camera stopped working after. It might of corrupted the files maybe?
Start over and give it time . I think I see what you did .I don't know just what you've done . Start up update takes a little while and that screen you put up is wrong for the standard .
Camera stopped working ...like what you mean .
The screen shot you showed has me buggered
Is that where you tried to update from ?
That's the one for you .
ogedOK I just powered mine up and when I opened the app it went straight to the standard screen and I can't swipe it to anything else .
Then I hit Enter Camera View and there I see the view from the camera . Not sure what else to tell you at this point .
