Hi folks, I'm glad to present you the result of my work.
A lot of us have been unhappy, because until now, there was no offline TXT FlightRecord to CSV Converter.
And after websites such as HealthyDrones and djilogs.com started to charge for their services, I decided I really need some offline converter. So I created it by myself.
It's quite simple, all you need to do is select input TXT file and output CSV file and press the GO button. There is also option to export JPG images, if they are present in the log.
I don't plan to add graphs, statistics or something like that.
My thanks goes to (for me) unknown person, who published some sources at this site, so I was able to put missing pieces together.
If you find any error, let me know.
Enjoy
Notice 1: It is confirmed that the TXT logs of Inspire, and also TXT logs from iOS app, have a little bit different structure (not known to me), so, please, don't be surprised when you see some strange values
Notice 2: Some of you requested the structure of the TXT log, so, here you have it too
- edit: since DJI GO 2.8.4, TXT logs are encrypted, so the structure file is useless
Notice 3: Tool can be also run from command line like this, example:
TXTlogToCSVtool "C:\temp\inputFile.txt" "C:\temp\outputFile.csv" J I G
It will try to read inputFile.txt and write the output into outputFile.csv.
Optional parameters:
J ... it will also export JPGs, if they are present in the log
I ... imperial units will be used
G ... it will also export GPX file
Notice 4: The tool is freeware and it is intended for your own personal use only.
Notice 5: Please, don't ask for decrypting algorithm. It's not shareable. Explanation here.
Notice 6: DJI is adding some misleading bytes into newer logs, so if primary version from TXTlogToCSVtool.zip doesn't work, try experimental version from TXTlogToCSVtool-exp.zip. For Mavic Mini logs, it's best to use TXTlogToCSVtoolMM.zip.
actual version is from 2020/01/24
Enjoy
