Shock absorbers
How to install shock absorbers. They are quite hard to remove from the white clips
It's easiest to cut off the clips with pliers.
No. Use the spare pins that came with your Phantom.
Should i put them on all 4 sides? My phantom cam with 2 installed diagonally
I use zip ties instead of the clips. Use fishing line or string to loop around the rubber shock things and pull one side through the holes on the gimbal part.
Sent from my SM-G920V using Tapatalk
Nope. Just use two. Four might cause jello in your video.
nicos18
