Sailboat Mast
Boston, MA and Sunapee, NH region
Put our mast up last week and left the main halyard at the top.
The mast is only 26' (30' from deck) so I can probably put a ladder part way up and use an extension pole to hook it.
But that got me to thinking: if I put a 2-3' long pole in front with a fish hook and line on it, might be able to use the drone to hook it on. It's a little tricky because a "crane" (horizontal extension about 9" long) is at the top of the mast so I can't go straight up or down, have to approach from the side.
Anyone ever try something like this? Here's what it looks like, but instead of the line coming down there's a knot under the crane.
View attachment 84398 Put our mast up last week and left the main halyard at the top.
Is pulling the boat down an option?
If you can pull it over towards a wharf or higher boat, you wouldn't have to tip so far??
Glad you've sorted it out. :)
If the mast is really that expensive and fragile then it's surprising that you yourself even mentioned and considered the possibility. I wouldn't have..
brianklenhart
