Thanks for the info.It will hover in place until the battery gets low and then land wherever it is.
Do you have any documents ( cant find it in the manual) or have you tested it?
I believe your right, but if I am flying in a valley it may occur. So looking for info on being prepared for that scenario.Without GPS, the Phantom can't find its way home.
But you're unlikely to be losing GPS unless you fly in a cave or a deep canyon etc.
You have to lose quite a lot of sky to lose GPS with the P3.I believe your right, but if I am flying in a valley it may occur. So looking for info on being prepared for that scenario.
Thanks
IF you lose GPS, your Phantom will default to atti mode.I want to be prepared in a situation where I DO lose GPS
There is no info I can find to indicate what it would do.
Ya will post back when I figure it out. Thanks for the infoThanks for asking this and forcing me got think about it more. I figured it would hover since that is the other fail safe option, but now that I think about it further it cannot hover in place without gps. As a result, I believe it would land after it loses RC signal for 3 seconds if gps is not available, but that is only what I think it will do. To test you would need to block gps (I have read aluminum foil on top will do this) and fly somewhere safe and then turn off the RC...I would not try this myself and anyone that does should take extreme caution...you could turn RC to gain control back in theory...I will edit my original post in case someone doesn't read the whole thread...
