Registering drone
When you guys get your registration number for your drone, where do you guys put the number on the drone and is a sharpie or stickers best way of doing it?
You can put the recreational use registration number anywhere that is accessible without tools, even inside the battery compartment if you wish. I printed the number on white paper, trimmed it tight, and just use Scotch tape to adhere it for a neater look than using a sharpie. You really don't see the tape or white paper against the white shell. For the commercial registration number, it needs to be easily visible so I printed it large and adhered it to the outer side of the rear prop arms. For that, I got a little fancier and printed the numbers on some clear adhesive film I had at the office.
Reactions: BigAl07
I placed my P3 stickers here:
If you need some stickers, you can get some from me here.
Reactions: PhantomMenace65
I use a label maker and put it inside the battery compartment. I print it as small as I can..... you'll need a magnifier.
Reactions: yorlik
Here... (as well as in the battery compartment)
These two (different) labels are on the opposite side of the drone, as well. I highly recommend a "Reward" or at least a phone number on your aircraft, as well.
tpren3
