And I see you have 73% batt. left! That's incredible... I went 13,000ft and used close to 50% batt.Ordered one of these printed/foil extenders for around $12 couple of weeks so. Finally had a chance to take it for a little test flight today.
That thing is magic. Went from 7000ft with signal loss to over 13,000ft with full bars and no loss of signal at all. Highly recommended!
Is there anyone that sells this item that's NOT in China?
Parabolic Antenna Range Booster fr DJI Phantom 3 Inspire 1 Controller Windsurfer on E-Bay.
I printed mine up about a month ago, then used aluminum tape on the curved surfaces. Got mine to go twice the distance easy.
There is also a horizontal distance limit, all you have to do is leave it off. It's off by default, as I recall. Anyone who has looked through the whole app and all the settings should be familiar with it.Its altitude.
One way?I have gone 5.3 miles with my Aluminum Parabolic Antenna Range Booster fr DJI Phantom 3
Please excuse a newbie response. If inappropriate, i will delete. I have a Phantom vision 2 that is "disconnecting at abour 200 feet both vertical and downrange. I think it is camera only. Seems to reconnect when I bring it in closer. Is that a wifi problem, and if so what is a good fix? I'm learning, but this one I don't quite understand.Ordered one of these printed/foil extenders for around $12 couple of weeks so. Finally had a chance to take it for a little test flight today.
very niceHello All,
Just wanted to let all the people know that were thinking of getting a Windsurfer to extend there range that they are on Sale now! at my website (I offer 3 styles of windsurfers) and also comes with a FREE GIFT! ($10.00 Value) for when your not using your windsurfer.
My windsurfers come fully assembled with reflective tape already on the windsurfer (It can be tricky not to get air bubbles when applying the reflective material) 2 - extra strips of reflective tape incase you damage the reflective surface. 2 - Locking clips to help keep everything in place & Instructions. I smooth out & Vapor seal the windsurfer surface to get the best Quality, Performance & life out of the part.View attachment 31937
Each of my windsurfers can take you passed 3+ miles with Optimal conditions. This entre process takes 3.5 hours but worth it. Orders Typically ships out in 3 days.
View attachment 31924 View attachment 31925
View attachment 31926 View attachment 31927
You also get a FREE Antenna spacer to use when your not using your windsurfer. It Slips over the ends of your Antennas to keep them parallel to prevent them from getting knocked out of alignment during flight allowing for Max range & uninterrupted video/signal. Also, its a great help when making adjustments during flight and it looks great!
These Top Quality items are and more can be found here: Dynamic 3D Solutions
Thanks again
~Dave~
This question probably should be in the Phantom 2 Vision forum, but my P2V acted that way when I had preview resolution set high - like 640x480. If I set it down to a lower setting the problem went away.Please excuse a newbie response. If inappropriate, i will delete. I have a Phantom vision 2 that is "disconnecting at abour 200 feet both vertical and downrange. I think it is camera only. Seems to reconnect when I bring it in closer. Is that a wifi problem, and if so what is a good fix? I'm learning, but this one I don't quite understand.
Look on YouTube. Try phantom windsurfer antenna booster or something to that effectSince you have not tried it yet, how do you know if the range increases?
It's so easy to make go on YouTube and put in toms tech time . You will be glad you did all the best and safe flyingIs there anyone that sells this item that's NOT in China?
Hello All,
Thanks again
~Dave~
