Severe overkill.......Does anyone think that this is overkill?
Considering that a prop could be damaged on even its first use, it would make better sense to routinely inspect them carefully prior to each flight. Change them when you notice any damage or wear around the locking mechanism inside of the hub. If the props don't strike anything, they should last for years.Does anyone think that this is overkill?
I've been replacing my props at 20 flight intervals, as a preventative measure.
Yep, overkill IMHO. No damage and properly balanced...Good to go!I've been replacing my props at 20 flight intervals, as a preventative measure.
