Phantom Vision won't take off
Discussion in 'Phantom 2 Vision Help' started by hilitephoto, Dec 28, 2013.
  1. hilitephoto
    I recieved the Vision for Christmas. Finally it is above freezing so prior to take off I update the firmware.
    Everything works alright until I try to take off. It dosen't seem to have enough power to take off even with stick all the way up.
    Out of frustration, I move the stick to the right a little bit and immediately the rpm's rise to a higher level. I then move it to the left and the rpm's rise again and it wants to rotate and lift so I throttle back all the way down and the props won't shut down. I shut the Vision down manually. Well I connect the controller to the RC software and attenpt to calibrate it. Thinking it will work having no idea if it calibrated succesfully I took it outside for another try. Same thing as before. Not enough power to take off and wont shut down. Yes, I am talking about the left stick.
    Thanks for any help!
  2. OI Photography
    Clarksville, TN
    When looking in the NAZA assistant, does the slider on the "T" channel move in direct and full proportion to your up/down movement of the left stick? It sounds like that's not calibrated, which may also require you to calibrate the controller itself and not just the ranges in the NAZA assistant.
  3. hilitephoto
    Got her up and flying! Funny thing, the flying is the easiest part!
    Thank you so much!!!!
  4. OI Photography
    Clarksville, TN
Similar Threads - Phantom Vision won't Forum Date
My Phantom 2 vision + won't connect to my laptop. I am having trouble with starting the motors. Phantom 2 Vision + Help Sep 18, 2016
Phantom Vision2+ Won't Power Up Phantom 2 Vision + Help Apr 23, 2015
Phantom Vision+ won't turn after first battery charge Phantom 2 Vision + Help Feb 17, 2015
Phantom 2 (non vision) Won't Power Up Phantom 2 Vision + Help Nov 15, 2014
phantom 2 vision+ won't power on Phantom 2 Vision + Discussion Nov 12, 2014
