I'm a newbie and my biggest complaint is the battery case - I have difficulties grabbing the connector. Today I found a lose red/gray wire - is that a problem? The unit flies fine even with the lose wire. Any suggestions on the case or lose wire?
ElGuano said:Can you post a picture of the wire? Is it really thin gauge, and clean-sheared at the end? Chances are you've pulled out the aux power connector that is supposed to rest at the bottom of one of the grommets under each leg of the landing gear. It connects very close to where the battery does and is there to provide you with additional 11.1v power for optional accessories. Having it exposed doesn't do anything one way or the other, but you do want to tuck it out of the way.
kearley said:Thanks for all the help - good news I guess. Here is the picture of the lose wire and bottom side of Phantom.
Kevin
