If you are in CE mode, you can use the windows application DIUpdate.exe, faster and safer than manually update to file system on remote/drone.Hii,friends. I am from Turkey and ı have use phantom 3 standart..
What should I do to increase the range of the device safety?
Sorry ı am beginner user. What is mean Ce mode or how will ı understand my phantom 3 standart in Ce mode?If you are in CE mode, you can use the windows application DIUpdate.exe, faster and safer than manually update to file system on remote/drone.
Before patch i made 1,5 km and lose video
I made the patch last one first option
And at the begining was ok... But at 1km i lose connection... And just before home the video came again...
Was very difficult to connect again the video... Before was much fast to reconnect..
Papatita the only files your app use and or disturb are djiled and watchlog?
Enviado do meu LG-V500 através de Tapatalk
Hi, i used DIUpdate.exe while on 1.6.8, now i donwgraded to 1.5.7 do i have run DIUpdate.exe again after downgrading?
Thank you!I did the same and it did appear to stick around. Just run the report section of the App when connected as see if it still says 27dBm.
Thank you!
By running the report section, do you mean "Step 2"?
yup. tested on mine.Will it work with 27dBm when using ARGtek?
On the official DJI's website, P3 Standard, Advance, and Professional, CE mode is 16dbm and FCC is 20dbm.
If you force the EIRP to 27dbm you have to consider for re-match your antenna using SWR meter. If not, you will burn your tx module soon. Maybe not at current flight, but soon it will be.
16 dbm = 40 mW (CE)
20 dbm = 100 mW (FCC)
27 dbm = 501.2 mW (1/2 Watt!!)
The heat produced by internal tx modul will effect with many different behaviour to your unit. Could be strightly burn the tx modul, or might be started with slightly by damaging other moduls besides; like disconnected WiFi, decreased tx quality, slowly reduced video quality, etc.
If you all insist using 27 dbm with no re-matching antenna, then I hope everything will be okay for long lasting. At least, always set the home point before long range flight with 27 dbm.
