P4 damaged ... what shall I do ?
Hi there,
I experienced my first P4 crash today and have found some damages on my bird
Does anyone know how to repair ?
Shall I repair before any further flight ?
Thanks for your answers.
Olivier
The only damage I see is the missing cover on the landing gear. Am I missing anything else?
DJI does not sell those landing gear covers separately. They come packed with the landing gear. You can buy a new set here on Amazon.
FYI, you should remove the gray foam block above your camera before flying.
Thanks. Yes, only damage is this cover missing.
I for sure remove the gray foam block to free the gimbal.
Do you advise to keep on flying or repair first by buying a landing gear set just for this missing cover ?
You're not going to hurt anything by flying it without that cover attached. To keep it free of any potential debris, you could wrap a piece of tape around the leg to cover the hole until you're able to get a new cover.
I got the same problem I lost the cover after i crashed what I did was just cut a piece of plastic and taped it with neon tape i did the same on other 3 sides to make it balance.
By the way I took the plastic piece from a water bottle
By the way i ask one of our local supplier for the parts but they don't sell the cover it has to be full landing gear which cost 100$
I noticed after flying my P4 just a handful of times (no issues) that the same piece was dislodged. I put a clear piece of tape on all of them as I've seen a lot of posts where these are coming loose and falling off.
Sent from my SM-G920V using PhantomPilots mobile app
tpren3
