P3S 5.3km with USD25 diy antenna
ych
Papatita 27dbm + China ebay antenna
signal is stable in 5km run
Reactions: hayato
sure, ipex to sma cable
Could you mind to share the taobao link? I found some 2.4g panel antenna but seems only one "hole" to connect.
Do you add amp for 5.8g antenna? Or just change it to "mushroom" antenna?
Thanks you help again. I'm from HK too. :)
2.4g panel antenna link
商品詳情
5.8g is no amp, mushroom antenna is bought at 星際 OTG hkd100
商品詳情
So what i need is
3 ipex to sma cable in RC.
3 sma to sma cable connect RC to panel antenna.
Right?
Do you have these 2 type cables taobao links? :p
I found some but very thin cable. Your thick cable should be better
Thanks your kindly help! ;)
So what i need is
Right?
2.4g pannel antenna x 1
5.8g mushroom antenna x 1
2.4g connection
N to RP-SMA connector x 2
RP-SMA M-F cable 300mm x 2
IPEX to RP-SMA 200mm x 2
5.8g connection
IPEX to RP-SMA 200mm x 1
商品詳情
30CM SMA公转母 路由器天线延长线 RG316耐高温线 跳线 馈线
商品詳情
