p1 controller antenna replacement
Can someone tell me where and what part number I need to replace the antenna within my controller? I have a screw in replacement antenna but ordered the wires that have the little clip on one end, and the threaded end for the antenna. After opening my controller I see that my antenna is soldered to the board. So I need an antenna wire that can be soldered on one end and has the threaded end for the antenna on the other end.
Thanks!
My board is the one in the lower right.
anyone help me on this? again, I need the part # for a direct solder to the board not the RP-SMA connector
I just soldered an RP-SMA pigtail to the board and used some JB Weld to hold the connector in place on the top half of the controller shell... That way it's secured, but the shell isn't glued shut. Works great and looks like it was stock :)
Scav8tor
