Major Vibrations P3P
I had a very similar experience, yesterday, after the FW updates...At a shallow hover about 4-6 ft off of the ground this weird shimmying would occur. Never seen it do that before. After a few settings & gains adjustments (taking them back to where they were before the update) still the same thing...
Then I remembered that I was playing with the controller while the update was installing in the Phantom, and I had inadvertently left the P-A-F switch, in F mode. Switched it back to P mode and shimmy was gone!
I went out today and the major vibrations ceased to occur..but I still have mild vibrations to the gimbal ..wondering the plastic pins should there only be 2 holds the gimbal to the Phantom or all 4 should be applied..?..I'm thinking the mild vibrations are the case for the Center of my pics to be blurry, look at the boats background all out of focus.., I have shot of me close up out focus..video as well..sometimes there is none but most of the time I see this..need to blow up the pic to see what I mean
Question I have what would cause all this major vibration one day..after 30 mins of flying and then today it's steady but mild gimbal vibrations ?
There is only supposed to be 2 pins on opposite corners. Some install zip ties loosely on other two corners. I had the same problems as you described when I switched motors to anti gravity T motors. ( this was on my P2V+)
We had to adjust the gains lower. Could your gains be off?
I have the same issue after upgrading from 1.3.4 > 1.4. > 1.5 on the craft and updating the RC firmware. Also did IMU re-calibration. You can see the whole gimbal assembly just shake after taking off and hovering. I just re-calibrated the RC and that did not seem to help. I'm going to try downgrading the firmware to 1.4 for fun.
Let me know if that helps
What should I look for in my gains if they are off, sorry newbie with the Phantom..i've had only about 12 flights now..thanks
Ok downgraded to 1.4 and did nothing more:
It looks to be gone or lessened.
this is pretty much how mine looks now, mild vibrations..but I didn't do anything, just another day of flying and seemed to be OK...still I am not happy with the blur in center of videos and photos.
I still think it looks to vibrate a bit, but its not as bad as it was.
Probably should look for other resolutions as the downgrade may not be the answer to vibrations.
Reactions: Static8
Well next step for me a prop balancer to eliminate that variable.
If you haven't balanced props or checked the motor hubs for balance-- yes.
