If you want to mod your bird I will be more than happy to let you borrow a set of my dipoles.
Is your 5.8 side boosted as well? Are you running 1 or 2 amps on the 2.4 side?
Incredible gesture.
I'll pm you to chat
Didn't Dirtybum say he was a bigger fan of stock bird vs. dipoles?If you want to mod your bird I will be more than happy to let you borrow a set of my dipoles.
l agree, its gotta make troubleshooting a pain in the rear too when u have both modifiedI believe he uses them on his P2 and P3 standard...not on his adv/pro. His 40,000+ run with the standard had birdside done. But with the antennas out now you really dont need to do birdside. Thats why I wont do it, because my TX side antennas are more than enough to get me really far if needed!
BTW is there an OFFICIAL (safe) order to power up the amps because of the spike? Some power amps then rc and opposite for others. l don't want too guess!
I agree with your thought here. I've always had the worst wifi signal from the front of the drone. Can go out without much of an issue, and as soon as I do a 180° and head back the signal starts cutting out until I get much closer to home. Take a look here on a flight I made today it's a perfect example of that. Just look at Sensors/Signal Map and General/Notifications HealthyDrones.com - Innovative flight data analysis that matters Did you ever try to relocate those wifi patch antennas?It seems the near term DIY I'm considering and researching is relocating the 2.4 patch antennas bird side.
If I understand correctly, the bird side 5.8's in the legs work pretty well as is; and the area for improvement is with video reception. I do notice I lose video first and always have problem getting it back. Would moving the patch antennas to front and back help with this? I rarely fly sideways. Or does the patch antenna broadcast horizontally to the sides in which the horizontal signal from antenna crosses its path for connectivity?
Trying to understand this handshake.
