I had that problem at one point. Try force quitting the app. Then try again. Then try switching the frequencies a few times to see if it finally allows you to access custom. I apologize I can't remember what specifically worked but once it did it stayed fixed.
Of course you could always delete the app and reinstall it.
Thanks, Ravedog!
I can't access the "Custom" setting. It's greyed out.
I know now why, some engineer in the DJI forum got back to me:
"Hi, the custom option is default to be blocked in Europe because of the politics. Hope for your understanding."
So I guess we Europeans must live with another DJI restriction...
Great, another black mark against DJI, I'm beginning to think I got the wrong droneThanks, Ravedog!
This is just my thinking i had a mini ipad2 updated the apple update and the dji update and my mini pad wasnt worth sh?t. so i went and bought a mini ipad4 i did not update to the latest apple firmware, and only use the minimum apps on it i just use it with my p3p, i dont have any problems now using it videos are fine, i believe between apples update and dji its now getting over worked by the updates and causes the video problemsok so now I'm also having a problem with my ipad and the DJI go app
Its giving me this message and I loose video all the time, in a matter of minutes, I can no longer do a hardware decoding option.. Any one knows how to fix this new problem on the 4 pro?
Sometimes when you use GO4 with an iPad Mini/Air/Pro, and the iPad Wifi is ON, the wifi will be searching for an access point all the time. If you are flying on the 2.4Ghz band, the wifi search can interfere with your video downlink, making you think you have an app overload problem, because this interference causes a broken up green screen, JUST LIKE when the Mini 2 overheats in 90F+ ambient temps. If you turn iPad Wifi off, that may help solve display problems, for iPad Mini2,Mini 4, Air2, & Pro devices. This exact problem happened to my friend last weekend, and after he turned his iPad Mini4 wifi OFF, the display started working like normal. It also worked OK when flying on the 5.8Ghz band, with the iPad Wifi ON, since the iPad wifi was apparently only hunting for an access point on 2.4Ghz band.This is just my thinking i had a mini ipad2 updated the apple update and the dji update and my mini pad wasnt worth sh?t. so i went and bought a mini ipad4 i did not update to the latest apple firmware, and only use the minimum apps on it i just use it with my p3p, i dont have any problems now using it videos are fine, i believe between apples update and dji its now getting over worked by the updates and causes the video problems
