Intelligent flight modes with new FW upgrade
Since the new firmware upgrade only the tripod mode works. All the rest do not. Anyone else having these issues??
Tried out the terrain follow this evening and it worked ok, but seemed like OA was causing it an issue if it sensed an uphill coming. Turning off OA (really toggling out of P) took it out of the terrain follow mode. Flying sideways mitigated that particular issue. That all said, I doubt I'll ever bother to use it again, myself.
I'm not having any problems with the Intelligent flight modes. Maybe calibrating your Obstacle avoidance sensor may work. You can do this in the DJI Assistant 2
Did you re-enable the "Multiple Flight Modes" setting in DJI GO?
Problem solved ..purchased a Samsung tab A 10.1 inch and all flight modes work perfect. Thanks for the responses.
Johnboy94
