GPS problem
Using Samsung Tab A, when in follow me mode it says no sensor found on device cannot integrate IMU data
Something to keep in mind that apparently even the "apple geniuses" don't know because I asked is that only the iPads (if you are using a mini or an air for the app) that have cellular also have the real GPS receiver which is necessary for follow me, and for setting better home points and the like. I found this out the hard way. I had just gotten a new iPad mini 4 wifi (not cellular) and I went to "follow me" mode and when I did it said "GPS signal to weak" but I had like 16 on the RC but that was the Inspire that had the SATs. The receiver (the phone) when using a non-cellular iPad uses crowd sourced hotspots, and wifi to help you achieve the GPS goals.
If you look at the specs (even on the Apple site) and you compare the non vs cellular iPads no matter which one it is under "Location" which is GPS it says for wifi "
  • Wi-Fi
  • Digital compass
If you ave a cellular, LTE, 4G or whatever you want to call it version the specs are
  • Wi-Fi
  • Digital compass
  • Assisted GPS and GLONASS
  • Cellular
Now you don't need to activate cellular but if you don't have an iPad with LTE than you DO NOT have a real GPS/GLONASS receiver and you are not going to get as fast or as good a signal from the bird to the RC because the RC uses phone for it's GPS. It should have been put in the remote if you ask me, relieving this problem.
Now, if you already have a wifi version and you want to have the GPS, there is a solution. It's with this.
Bad Elf GPS with Lightning Connector
That thing above is really awesome actually. If you have a iPad mini 2 for example, follow me wont work. Insert that little guy above and it will work perfectly. Most people at Apple or DJI don't seem to know this BTW. Took quite a bit of research the other day. Luckily I had just bought the mini and I was able to bring it back but I was so annoyed because the dude had told me it had GPS and I just believed him and luckily, the wifi where I was flying it from gave me enough to have a map and see the bird and all.
Yes, you can use the Follow Me feature on the iPhone 5s.
But you won't be able to with the iPad Mini unless you get the cellular version and YOU DON'T need to activate the cell service. There is no GPS receiver in your iPad mini 4 wifi but there is in your 5s, all the 6s, and all the iPad mini 2 and forward with cell.
But the "Bad Elf" (above) with the Ipad 4 Mini will work?
Yes. The Garmin GLO is another (less expensive) popular choice. You can find some other commonly used GPS receivers here.
dlr11164
