Go pros?
So I've tried using the search function to find out, but when I'm using my immersion transmitter and a go pro 3 black,I don't get a feed. When I use my go pro 3 + black I get feed. Any suggestions to get it working?
Are you using the USB ribbon cable or the GoPro 30 pin plug?
If you have the H3-2D or v1 H3-3D which both use the Hero Port to connect the camera to the gimbal then you won't get FPV output. You'll need to use the H3-3D v1.1 Gimbal with a USB Ribbon Cable.
The 3+ Black works fine with the 30 pin connector. It's the Hero 4 Silver and Black that don't get video out from the 30 pin connector.
Keep in mind that both of them (monitor and gopro have to be in the same either NTSC or PAL
AnndyManuka
