Firmware 3.0 & Assistant Software 3.0 ??
Gonzoshots said:
WHere are you flying? Seems like there is some correlation to long lat.
My obvious first issue was with the craft no longer holding altitude and the loss of altitude when going forward or backward, just slowly descends with zero change in throttle.
italy, but i didn't make some precise test yet.... i ll try and post the result
PhotoPilot said:
I think the moral of the story here is "Don't update your firmware unless you have to" If it aint broke, Don't fix it.
EXACTLY! I will probably never update. V 1.0.8 works beautifully for me, not problems at all.
Hi,
just read the hole topic after just receiving my 3D. Very disappointed from DJI as the Gimbal doesn't fix properly on the version of my phantom(came with 2D) so need to takes tools and modification to fix it.. :cry: crazy that they don't made something works on all phantoms 2…the future of possible..i guess..
Anyway now i'm confused, i want to upgrade i never use assistant software so i guess i'm on 1.8 (?) since i bought it ( ending february)
For the 3D does i need 3.0 or 2.0 is enough ?
i'm on mac and on the website of DJI i read several different versions of software for P2 :
MAC
Phantom 2 Assistant Software v3.0 2014-04-07 DMG
Phantom 2 Assistant Software v2.00 2014-03-26 DMG
Phantom RC Assistant Software v1.1 2014-02-20 DMG
i can run 1.1 with 2.0 ?
WHY for windows it's existing some more software ??? :shock:
@Phantom 2 Main Controller Firmware* v3.02
@Phantom 2 Central Board Firmware* v1.0.1.25
Appreciated your support, to let me know which i should run ?!
:roll:
Use version 2.0 and 1.1. Most things are Mac compatible but there are a few that are not. I only needed to use a PC for my iOSD Mini and even then I probably didn't need to update it anyways.
Once you plug in your Mac to the P2 you'll understand better. It will let you know if there are updates to do. Just don't update from 2.0 to 3.0 unless you find a real need to. Calibrate everything.
The online manual - http://download.dji-innovations.com/downloads/phantom_2/en/PHANTOM2_User_Manual_v1.1_en.pdf
DJI support page - http://www.dji.com/support
Thanks for your support and links ;) , i will go on 2.0 and 1.1. Nope 3.0 as i see so many negative feedback for now... :roll:
Scav8tor
