Re: fc40 camera put a .txt file today on my card that was ne
Re: fc40 camera put a .txt file today on my card that was never there before today called dsp.log and its got all sorts of stuff that looks like configuration codes. don"t know if this will be helpful to any one to figure out what it all means or if messing with it and editing it will allow any one to change any thing in the camera
[code:th2:14321] TH2 MEMD memd_hl_wait_ll_complete: start to wait at , 85129794
[code:th1:14322] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 257412
[code:th1:14323] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 244395
[code:th1:14324] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 231567
[code:th1:14325] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 218922
[code:th1:14326] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 206276
[code:th1:14327] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 193581
[code:th1:14328] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 180782
[code:th2:14329] TH2 MEMD memd_hl_wait_ll_complete: waited out at , 85224335
[code:th2:14330] TH2 MEMD log_memd_result : start at , 85224651
[code:th2:14331] TH2 MEMD log_memd_result : end at , 85224802
[code:th1:14332] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 167954
[code:th2:14333] TH2 MEMD memd_send_msg : send at , 85233024
[code:th2:14334] TH2 MEMD memd_hl_init_basic_dram_buf_talbe : start at , 85233421
[code:th2:14335] TH2 MEMD memd_hl_init_basic_dram_buf_talbe : end at , 85237211
[code:th2:14336] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: start reorder at , 85240807
[code:th2:14337] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: end reorder at , 85241626
[code:th2:14338] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: start dpb at , 85243231
[code:th2:14339] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: end dpb at , 85243425
[code:th1:14340] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 154934
[code:th2:14341] TH2 MEMD memd_hl_init_dma: start at , 85246772
[code:th2:14342] TH2 MEMD memd_hl_setup_whole_flexible_smem_allocation: start at , 85246885
[code:th2:14343] TH2 MEMD memd_hl_setup_whole_flexible_smem_allocation: end at , 85248192
[code:th2:14344] setup smvmax=40
[code:th2:14345] setup smvmax=40
[code:th2:14346] setup smvmax=40
[code:th2:14347] setup smvmax=40
[code:th2:14348] TH2 MEMD memd_hl_init_dma: end at , 85253127
[code:th2:14349] TH2 MEMD memd_hl_wait_ll_complete: start to wait at , 85253628
[code:th1:14350] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 141880
[code:th1:14351] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 129032
[code:th1:14352] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 116324
[code:th1:14353] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 103571
[code:th1:14354] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 90902
[code:th1:14355] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 78242
[code:th1:14356] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 65574
[code:th1:14357] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 52935
[code:th2:14358] TH2 MEMD memd_hl_wait_ll_complete: waited out at , 85347422
[code:th2:14359] TH2 MEMD log_memd_result : start at , 85347723
[code:th2:14360] TH2 MEMD log_memd_result : end at , 85347880
[code:th2:14361] TH2 MEMD memd_send_msg : send at , 85355952
[code:th2:14362] TH2 MEMD memd_hl_init_basic_dram_buf_talbe : start at , 85356402
[code:th1:14363] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 39905
[code:th2:14364] TH2 MEMD memd_hl_init_basic_dram_buf_talbe : end at , 85361143
[code:th2:14365] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: start reorder at , 85363911
[code:th2:14366] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: end reorder at , 85364412
[code:th2:14367] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_encoder_process_one_round: end to process main at , 85364598
[code:th2:14368] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_encoder_process_one_round: start to process second at , 85365542
[code:th2:14369] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_encoder_process_one_round: end to process second at , 85366308
[code:th1:14370] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 26881
[code:th1:14371] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 14143
[code:th1:14372] turbo command timer setup non TURBO_COMMAND_SUB_PERIOD: 1340
[code:th1:14373] CAPTURE_MODE_EIS_turbo_command_mechanism_2_check_update
[code:th1:14374] CAPTURE_MODE_EIS_trubo_command_mechanism_2_get_eis_coeff step from dram 0x0
[code:th1:14375] CAPTURE_MODE_EIS_trubo_command_mechanism_2_get_eis_coeff not performed step with NULL eis_udpate_addr
[code:th1:14376] CAPTURE_MODE_EIS_turbo_command_mechanism_2_check_update not performed
[code:th1:14377] CAPTURE Start to wait command 1 at , 85401102
[code:th1:14378] CAPTURE Finished to wait command 1 at , 85438984
[code:th1:14379] CAPTURE start to wait command 2 at , 85439079
[code:th1:14380] CAPTURE Finished to wait command 2 at , 85441785
[code:th1:14381] idspdrv_compose_idsp_cfg Sec:3 Mode:0 Table:0x0000 Size:256 Addr:0x40569c0 [end]
[code:th1:14382] CAPTURE mctf_hl_wait_one_picture: start_wait_mctf at , 85451014
[code:th1:14383] CAPTURE mctf_hl_wait_one_picture: end_wait_mctf at , 85451252
[code:th1:14384] CAPTURE mctf_hl_wait_one_picture: start_wait_sec_3 at , 85451405
[code:th1:14385] CAPTURE mctf_hl_wait_one_picture: end_wait_sec_3 at , 85451537
[code:th1:14386] CAPTURE mctf_hl_wait_one_picture: end_wait_sec_4 at , 85451561
[code:th1:14387] CAPTURE mctf_hl_wait_one_picture: end_wait_sec_4 at , 85451593
[code:th1:14388] TH1 MCTF mctf_hl_start_one_picture: start_send_msg at 85451895
[code:th1:14389] TH1 MCTF mctf_hl_start_one_picture: end_send_msg at 85452267
[code:th1:14390] TH1 MCTF mctf_hl_start_one_picture: end_start_sec_3 at 85452388
[code:th1:14391] CAPTURE Finished capture perform at , 85453080
[code:th1:14392] idspdrv DIGITAL GAIN mul 10340 10000 10000 22790
[code:th1:14393] TH1 sendInterrupt at , 85459822
[code:th1:14394] preview_state_prev_B_prepare_thread_mode_ex1: prev_A_duplicate_stat is 0
[code:th1:14395] CAPTURE start_code_enc_th2_main start at , 85467532
[code:th1:14396] CAPTURE start_code_enc_th2_main end at , 85468089
[code:th1:14397] CAPTURE Finished capture handling at , 85468276
[code:th1:14398] CAPTURE CAPTURE_MODE_14_encoder_post_perform_one_capture: no need to process anything since its the cmd_deadliline is not negative at , 85468732
[code:th1:14399] CAPTURE Prepareing the capture cmd here at , 85470278
[code:th1:14400] idspdrv_compose_idsp_cfg Sec:1 Mode:1 Table:0x0000 Size:256 Addr:0x402a040 [end]
[code:th1:14401] CAPTURE Start compute act win at , 85473839
[code:th1:14402] video_process cfg actual zoom_y_start_frac 0 zoom_x_start_frac 0
[code:th1:14403] video_process cfg actual VIDEO_PROCESS_WIN_GET_ACT_WIN_HEIGHT 712 VIDEO_PROCESS_WIN_GET_ACT_WIN_WIDTH 1280
[code:th1:14404] video_process cfg actual VIDEO_PROCESS_WIN_GET_ACT_WIN_LEFT_EDGE 0 VIDEO_PROCESS_WIN_GET_ACT_WIN_TOP_EDGE 0
[code:th1:14405] CAPTURE finished compute act win at , 85474211
[code:th1:14406] capture_calc_cfa_output_for_zooming: *p_cfaOutputNumRows is 712
[code:th1:14407] capture_calc_cfa_output_for_zooming: *p_cfaOutputNumCols is 1280
[code:th1:14408] idspdrv_set_vin_active_win raw x:0 y:0 w:1280 h:712
[code:th1:14409] idspdrv_set_vin_active_win act x:0 y:0 w:1280 h:712
[code:th2:14410] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_encoder_process_one_round: start to process main at , 85476997
[code:th1:14411] idspdrv CFA H phase inc 00000000 00002000 Zoom 00000000 00000000
[code:th1:14412] idspdrv CFA V phase inc 00000000 00002000 Zoom 00000000 00000000
[code:th2:14413] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: start set coding properties at , 85480730
[code:th2:14414] last pts is 1069068 extra pts interval is 0
[code:th2:14415] last pts is 1081080
[code:th1:14416] idspdrv AAA_STATISTICS_SETUP (AWB) w 52 h 44 active_w 52 activ_h 44
[code:th1:14417] idspdrv AAA_STATISTICS_SETUP (AE) w 106 h 88 output_w 1280 output_h 712
[code:th1:14418] idspdrv AAA_STATISTICS_SETUP (AF) w 140 h 140 active_w 140 activ_h 140
[code:th2:14419] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: end set coding properties at , 85483120
[code:th2:14420] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: start reorder at , 85486316
[code:th2:14421] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_pure_encoder_process: end reorder at , 85491277
[code:th2:14422] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_encoder_process_one_round: end to process main at , 85491789
[code:th2:14423] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_encoder_process_one_round: start to process second at , 85494110
[code:th1:14424] idspdrv_compose_idsp_cfg Sec:2 Mode:5 Table:0x0000 Size:9216 Addr:0x402b0c0 [end]
[code:th1:14425] CAPTURE Finished command preparing at , 85497999
[code:th1:14426] thread_event_flag_get_cb()->capturing_frame_time_limit : 371371
[code:th1:14427] thread_event_flag_get_cb()->latest_captured_frame_time : 85438800 : Current time is 85498191
[code:th2:14428] TH2 MEDIAPROCESS MEDIA_PROCESS_MODE_4_encoder_process_one_round: end to process second at , 85498596
[code:th1:14429] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 311020
[code:th1:14430] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 298216
[code:th1:14431] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 285554
[code:th1:14432] turbo command timer setup TURBO_COMMAND_SUB_PERIOD: 272865
