DJI Phantom 1 maximum battery
Hello, can you tell me what is the biggest battery i can put on my dji phantom 1? I currently have 2200mah battery but i need bigger ones :)
With some modification of the battery opening you can fit a Turnigy MultiStar 4000mAh battery in there. I've actually modified my FC40 extensively with velcro to allow even bigger batteries and am hoping I can fit MultiStar 5200mAh batteries in as soon as HobbyKing get some UK stock in.
I 3D printed a dummy battery with the right dimensions and although it does stick out quite a bit it does fit with a large enough opening.
the multistar 5200mah can fit - see the post below
viewtopic.php?f=29&t=28392
you will need to remove the rails in the battery compartment, and use a carving pen to widen the opening of the battery bay.
it does fit!!!
brianklenhart
