Dead Gimbal after firmware update.
I updated the firmware on the P4Pro today. After the upgrade the Gimbal stopped working. I have attached two pics to show you what I see. Any ideas?
How exactly did you update the firmware?
Reactions: Heiifyre
Which firmware versions do you see in the "General Settings" --> "About" section of DJI GO?
Reactions: Heiifyre
When I powered up the phantom it said there was an update that needed to be applied. I downloaded it through the app and followed the install instructions. It did install without issues. I put it away and charged the battery. When I was ready to use it again the gimbal had stoppped working.
Shut down your Phantom, remove the memory card, and start everything up. Do you still see this issue then? If not, format your memory card.
Nope. It came up without the memory card. As soon as I put the card back in it stupid working again.
I'll format and let you know!! Thank you.
Do you think was this caused because of a corrupt card from not formatting correctly or not ejecting it correctly from a reader? Again! Your a wizzard when it comes to these birds msinger!
I'm not sure why it requires formatting sometimes. I know the firmware update process reads/writes files to the memory card, so I've always assumed it sometimes leaves something behind that shouldn't be there.
Reactions: KevMo Photog
2018... Similar problem, easy fix.
"No image transmission..." It's the mSD card if you see the gimbal mechanics working... See below
Scenario: P4P, RC, Gimbal, Camera, everything previously working well.
Problem: Everything but Gimbal camera connection working fine. RC Message "No Image Transmission"
Specifics to Problem: Gimbal mechanics are working, but no image on the RC screen. Slight delay in shutting drone down.
Recent change: Added DJI/Seagate GoFly EHD without problems and treated the SD card the same as always.
FIX: Power on RC
Start DJI Go app
Power on P4P...
No active image on RC? "No image transmission" error seen somewhere?
- my camera mechanic were still working as normal at this stage...
Shut down P4P
Take out mSD card
Start up P4P.... Voila! Image transmission now should be working.
Results check: shut down P4P, insert another mSD card, turn on P4P..... all still working.
Findings:
Retried problem mSD card same issue, No Image Transmission and no image on RC media screen.
Format SD card function did not work for me. My research revealed sometimes this did show up for some and the able to reformat the mSD card.
Installed non working mSD card into a card reader and removed all existing folders, including "DCIM".
Reinstalled "non working mSD" card into P4P after deleting any remaining folder... REFORMAT Function now available. So far everything is working!!
AnndyManuka
