There's no published data but reading recorded flight data, it's clear that the compass is able to resolve very small angles.But I am looking for specific number of the tolerance of the compass.
For example if I am telling the drone to take a picture from 90° relative to the north, how much it is accurate.
We are talking about tolerance of 1-2 degrees or 10-20
Here's some sample compass data from a slow turning flight (highlighted in green).I just have mission from customer to take pictures from specific degrees relative to north, I plan to do it with litchi app.
It shows that the compass is measuring to 0.1°
I'm not sure how knowing that makes any difference even if you could find a way to display the heading while you fly.
Because the camera has a very wide angle lens a difference of +/- 5° wouldn't even be noticed.
But I don't find the spec of the compass that I can tell him exactly what is my tolerance
Your best bet is to use Google Earth to determine where you want to shoot from.Thank you for you answer,
Yaw is based on True North.That's fine but it references to what the Compass see's as its determined Compass to Magnetic North.
If the OP can live with not having exact True North as ZERO and use the angles to select +5 .. +10 etc. then if you can display what the compass output is ... maybe that's good enough ?
That would be precision. Not accuracy. ;-)Here's some sample compass data from a slow turning flight (highlighted in green).
The Yaw values scale is aligned with True North. If Yaw = 0° then the AC is pointing true north. That's assuming that 1) the AC has acquired enough sats to know it's position and 2) the compass is calibrated.Yaw is the level rotation of a vehicle such as aircraft / boat etc. Please explain where you get YAW is based on True North ?
Yaw doesn't care ... all it is, is a level rotation about an axis ... as in using rudder on an aircraft or putting the left stick to side ...
It sounds like you have misunderstood the meaning of the yaw value used by the flight controller. It's the angle between the horizontal projection of the aircraft x-axis and the direction of true north. It's therefore the aircraft's true heading.
