{EDIT: My Drone is a Standard, just realized that there is a SE and a Standard version. Sorry}
i've bought an used Phantom 3 SE and it's RC antenna aren't the original ones. Drone works normally and then around 60 ~ 100m the signal is gone and drone start the return to home functionally. As soon as i looked over the internet i found that those antennas are a from a "Give me Five" company. Also, i found that normally are 2 panels and one Anthena, instead of mine (2 ant / 1 panel).
I know the issue about the dead chip on antenna trigger and mine is dead... I did the soldering between the one connector to other on the chip to try as a solution but it didn't.
The question i have is... Are these antennas correct? I found that there is some modifications inside, silicone in some parts... is this some kind of modification?
Also, i found this kit, would it help?
Thank you in advance.
